Water is still boiling over with or without new thermostat. New AC fan assembly, new radiator cap. Appears to not run hot while moving. But does eventually while idling. No water in oil or oil fill cap. No white exhaust smoke. Appears normal amount of condensation in the exhaust.
Possible clogged radiator?
Possible head gasket, minus most symptoms?
Jun 23, 2017 at 1:03 PM
