Engine overheating
240,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
BOBWALKER26180
Engine runs at normal temperature on highway but overheats when going through slow city traffic or while waiting in Drive-thru.
Aug 4, 2020 at 2:12 PM
  • 110,248 POSTS
Based on your description, it sounds like the cooling fan isn't operating. Does this happen when the A/C is on or can it happen regardless? I'm asking because there could be an issue with the electric fan or the fan clutch.
Here are a few links to help you better understand:
https://www.2carpros.com/articles/how-a-clutch-fan-works
https://www.2carpros.com/articles/fan-clutch-symptoms
https://www.2carpros.com/articles/how-an-electric-cooling-fan-works
Aug 4, 2020 at 3:50 PM
BOBWALKER26180
After reading these helpful hints,I believe my fan clutch is bad.I do not hear the fan engage when I am in traffic even when it's 90+ degrees out.Don't remember the last time I have heard it work.
Aug 5, 2020 at 12:56 PM
  • 110,248 POSTS
When the fan clutch is fully engaged, it sounds like a jet engine. LOL Honestly, chances are that is the problem then. If it isn't turning fast enough, it won't help cool the vehicle the way it needs. Keep in mind, it engages slowly, but if it is overheating, it should be full engaged and you should hear it.
Here is a link that shows in general how one is replaced:
https://www.2carpros.com/articles/fan-clutch-removal
Let me know if you have questions or need help.
Aug 5, 2020 at 4:08 PM
BOBWALKER26180
Thanks, a mechanical friend of mine thinks it is the fan clutch also. With 240,000 miles, I am going to change it.Thank you very much.
Aug 6, 2020 at 1:52 PM
  • 110,248 POSTS
You are very welcome. Do me a favor. If you get a chance, let me know if that takes care of the issue. Your reply will likely help others in the future.
Aug 6, 2020 at 4:55 PM
BOBWALKER26180
I took my vehicle to a local mechanic and the problem was a bad fan clutch.Thanks for your help!
Aug 14, 2020 at 12:10 PM
  • 110,248 POSTS
Thanks for letting me know. I suspected that was the issue. Regardless, I'm glad you got things taken care of. Please feel free to come back anytime in the future if you have questions.
Take care of yourself.
Aug 14, 2020 at 2:22 PM
