We need to start with finding out if the engine is actually overheating or is the temperature gauge just rising?
You can use an infrared temperature meter to determine if the engine is actually getting hot unless the coolant is boiling over.
https://www.2carpros.com/articles/how-to-use-an-infrared-temperature-meter
If the engine is actually overheating then we need to ensure the cooling fans are coming on and the coolant is not low. Here is a guide that will run through the basics. Also, we need to check for blockages in the cooling system and you can use the temperature meter for that as well. You should have equal temp all around the motor and cooling system.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Let me know and we can go from there. Thanks
Mar 2, 2020 at 6:16 AM
