Engine noise when driving on high speed
70,000 MILES • AUTOMATIC
ARRANALFIEE
  • 6 POSTS
Hello all, my car's engine seems to be normal. It does not make noise etc on low speed or idle. But when I accelerate and drive it on high speed. Then its engine noise loud. I checked other Civic's of the same model. But they were not creating that much noise. What could be issue?
Also recently, I washed the car at service station. After that, I noticed when I turn the steering wheel either to right or left. It also creates sound.
Please help.
Thanks
Aug 24, 2017 at 12:50 AM
  • 55,721 POSTS
It sounds like you need to flush your power steering fluid which will make the sound you are describing.
Here is a guide to help you get the job done:
https://www.2carpros.com/articles/power-steering-fluid-flush
Cheers, Ken
Aug 25, 2017 at 4:25 AM
ARRANALFIEE
  • 6 POSTS
The sound does not come from steering. It comes from the front tires sides when I turn the wheel to left or right and also when I drive on high speed like seventy mph. I hear loud noise.
Aug 25, 2017 at 4:46 AM
  • 55,721 POSTS
It can be bad axle bearings, tire or transmission. if you could make a video and give me the link this would be better. I could tell you more accurately.
https://www.2carpros.com/articles/bearing-hub-replacement
I am not sure.
Aug 25, 2017 at 1:13 PM
