Can someone help me with videos on how to replace engine mounts or seats along with the gear mount on my car listed above?
Jan 24, 2018 at 5:04 PM
STEVE W.
✓Experienced Mechanic
That van was not sold in the US but the mounts should be about the same as most other mounts. You use a wrench to break the bolts/nuts free. Then use a jack or cherry picker/engine crane to slightly lift the engine to take it's weight off the mounts. Then remove the bolts/nuts and remove the mounts. Do one at a time so that the remaining mounts will hold the engine in the proper location as you work. This looks like it could help as it is mounts for a similar engine with a similar platform.
