Engine missing during acceleration
2006 FORD F-150
160,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
TOM MCRAY
When I accelerate going up inclines engine has a miss sometimes on level ground it miles it is bees around.
Nov 24, 2016 at 9:15 AM
WRENCHTECH
  • 20,761 POSTS
Probably a bad coil or two. You will have to determine which ones using a scan tool. Unless they were just recently done, you should change all the plugs at the same time.
Nov 24, 2016 at 1:53 PM
