So about a week or two ago I had a code P0301, I replaced the spark plug and coil pack and it ran perfectly. Then yesterday the engine started to misfire again and the same code pop back up for the same cylinder. I need help so identify the problem, and I don't have a lot of money to take it to a mechanic to find out. I'm wondering if it could be the coil pack or the spark plug that I just replaced because it was running just fine for 2 weeks. Or what else I can check to fix the problem?
Feb 20, 2021 at 6:22 AM
