i used my car to make a 450 mile round trip without any problems. i went to use the car next day and it just stalled in reverse and i got an engine malfunction display. The car will only crank over a few times then stops. I checked for codes with an obd2 scanner, no codes found, then i found 4 DTC codes on test mode.
DTC 1- C415-64
DTC 2- C422-64
DTC 3 1607-82
DTC 4 C100-00
DTC 1- C415-64
DTC 2- C422-64
DTC 3 1607-82
DTC 4 C100-00
May 5, 2020 at 9:13 AM
