ENGINE LOSS OF POWER
2008 TOYOTA VAN
5,007,622 MILES • 7.0L • 4 CYL • TURBO • 2WD • AUTOMATIC
CAR MAX AUTOS
HALLO am john from kenya. and motor vehiche technician. i got customer his vehicle got a problem of loss of power, hand to start in the morning. i have tried to check it out no any code illuminate when i tried to diagnose the ECU say system is ok what could the problem?? thanks for your sapport 2 car pros
Jan 25, 2016 at 2:00 AM
  • CERTIFIED EXPERT
check the fuel pressure first. check compression to verify timing. lastly, it could be a clogged cat converter, if it has one
Jan 25, 2016 at 5:48 AM
