Engine light, traction yellow sign turned on while driving
2008 AUDI A3
89,000 MILES • 1.6L • 2WD • MANUAL
AFAQ SALEEM
I was driving my car when it suddenly stopped in middle of road, with a traction yellow sign on meter screen. after 5 or 6 attempts I was able to start. I came home and it was showing EPS , Traction and engine check light. It wasn't starting after that. i had to call a mechanic and he attached a booster with my car and it started immediately and he said it is a battery problem.
Now i have ordered a new battery but my car RPM's is a bit lower than normal and it is going up and down and making the car shiver , plus the pick up is not the same.
I was going to get it checked by one of the mechanics.
any advice what the problem can be?
Thanks
Oct 10, 2019 at 4:46 AM
  • 110,236 POSTS
Welcome to 2CarPros.
It makes sense that if the battery was getting weak, the lights could have come on. Now, any time you replace the battery, there is a relearn period until the computer resets itself. How long has this been happening?
Next, since the battery is new, there still could be a charging problem. Here is a quick link that explains how to check the charging system (alternator). It takes about 2 minutes.
Here are a few links you may find helpful when checking the alternator. I suggest doing this just so we know it's working.
Let me know if any of this helps or if you have other questions.
Oct 11, 2019 at 11:03 AM
