Engine light on and code P0301
166,000 MILES
MOONANDBACK
Engine light came on, so took it to auto parts store and got a code P0301. so what should I do?
Oct 29, 2019 at 2:05 PM
  • 110,248 POSTS
Welcome to 2CarPros.
That is a cylinder 1 misfire. The first thing I would suggest is to remove the spark plug and inspect its condition. If you haven't tuned the vehicle in a long time, the plugs may be getting bad.
Also, confirm there is not damage to the spark plug wire.
Here is a link that explains in general how a tune up is done. It shows what are called coil over ignition coils. Your vehicle will have a distributor cap and wires.
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Let me know when the last tune up was done.
Oct 29, 2019 at 2:43 PM
MOONANDBACK
Oct 29, 2019 at 2:48 PM
  • 110,248 POSTS
Welcome back:
You are very welcome. If you let me know what you find, I will be better able to help you with a solution.
Take care and I'll keep an eye out for your return.
Oct 30, 2019 at 10:45 AM
