Engine light and codes u112b, u112bpd, u0100 and u1101
80,000 MILES • 6 CYL • AUTOMATIC
DSTEP
  • 7 POSTS
I have u112b, u112bpd, u0100 and u1101 codes. Just want to know if these codes are related to each other and if it something that might be costly.
Aug 28, 2020 at 4:23 AM
  • 110,248 POSTS
The codes you indicated are:
U112B No message from instrument cluster
U1101 Component protection
U1100 - Invalid Or Missing Data For Primary Id
I need you to recheck the U112BPD.
__________________________________-
Based on these codes, I would think there is a break down in what is called the CAN bus system. CAN stands for computer area network. The modules in the vehicle are all connected and speak to each other via this system. For the code U1100 to be set, one of the modules is not communicating (hence, the missing data for primary ID). In this case, and please understand this is a theory, I suspect the break down is from the instrument cluster itself.
What needs done? What I would suggest is to scan the CAN bus system to see if there is a specific code identifying where the break down in communication exists. Chances are as I said, it's from the cluster.
Here is a video that shows how to scan the CAN bus system:
https://youtu.be/InIlnsjOVFA
As far as providing a cost, I feel it could be diagnosed in approx an hour. Specific part costs will be determined by what is found faulty. Keep in mind, it could be a broken or damaged wire.
I hope this helps. Let me know if you have other questions.
Aug 28, 2020 at 7:29 AM
DSTEP
  • 7 POSTS
Thank you for your detailed response. I find this information to be very helpful
Aug 28, 2020 at 1:20 PM
  • 110,248 POSTS
You are very welcome. If you have other questions, feel free to ask. Also, if you have a chance, let me know what was found. In all honesty, it will likely help others in the future.
Aug 28, 2020 at 2:25 PM
