Engine issue
168,100 MILES • V6 • AUTOMATIC
ANDREW DURK
I have the XL. The check engine light has been flashing randomly, engine shaking, rpm moves up and down two or three times after I start it from being off for awhile, jerking around sixty mph. I do not know if this is related, but I have been hearing a popping or crackling sound in the dashboard behind steering wheel, dashboard A/C area. Thanks.
May 18, 2017 at 3:41 AM
HMAC300
  • 48,601 POSTS
the noise may be related it may be a misfire, have it scanned for codes auto parts does for free then get back to us with the code. it may be a plug wire shorting out on engine block making the noise.
May 18, 2017 at 5:14 AM
