engine idle high in park , and sometimes in drive
1997 TOYOTA 4RUNNER
240,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
DEEBRA
my toyota 4 runner started idling high in park for several weeks, then it also started doing it in drive, made car when driving speed forward, not always but every now and then, but the high idle at about 2400 rpm is constant now. have changed every sensor almost, changed air mass flow, cleaned everything, check hoses, just stumped at how to fix it, only codes it shows is coolant temp sensor ( did change the radiator about 2 months before this started ) but does not seem like that would have to do with idle, could it be the computer ??
frustrated, i dont have anyone to help me with this, single disabled woman. HELP PLEASE !!
Nov 17, 2015 at 9:17 PM
HMAC300
  • CERTIFIED EXPERT
  • 48,601 POSTS
replace coolant sensor then check for a vacuum leak and clean throttle body and iac hole with choke cleaner.
Nov 18, 2015 at 7:03 AM
