Engine fault code
245,233 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
SCLA0001
On Saturday and today the car stereo system keeps shutting off and restarting on its own for approximately one to two minutes along with the engine. gave a jump and then shut off and restarted within one minute after the stereo system did its own shut off and restart.
The same happened today, however the engine did not restart and the check engine light was on.
I used a Launch Creader VIII scan tool and the engine code read
P1320 -ignition signal-Primarygtc status 29.
Check engine light off.
What do I need to do now?
Dec 11, 2017 at 12:15 PM
STEVE W.
  • 15,411 POSTS
P1320 is a primary ignition failure code, most likely a bad coil or bad signal to the coil. If you run a spark test I would bet you don't have any.
If no spark and the trigger signal is getting to the coil it is a bad ignition coil.
Dec 14, 2017 at 11:34 AM
