engine/emission light
1997 VAUXHALL CORSA
131,000 MILES • 1.2L • FWD • MANUAL
BUSTABOI92
my warning light shaped as an engine has come on my car. I was just wondered if you new what it could be? i think it might be the exhaust missions it has a straight through cherry bomb exhaust does not sound to good anyway.
Dec 27, 2016 at 6:40 AM
CARADIODOC
  • CERTIFIED EXPERT
  • 34,308 POSTS
The Engine Computer has detected a problem, set a diagnostic fault code, and turned the Check Engine light on to tell you. There are over 2,000 potential fault codes. About half of them refer to things that could adversely affect emissions. Those are the codes that turn the Check Engine light on.
The place to start is by having your mechanic read and record the fault codes. Those will indicate the circuit or system that needs further diagnosis, or the unacceptable operating condition.
Dec 29, 2016 at 3:28 PM
