engine cutting off, car wont start
56,000 MILES • 1.6L • MANUAL
KEVROBBY
  • 5 POSTS
Engine sometimes cuts off when approaching junction whilst I have my heaters, lights and windscreen wipers on, usually early in a morning (5.45ish) when its cold and sometimes raining. Had tests carried out on the car, they reported that the battery was good just needed a good re-charge, had a starter test that found cranking was normal and also underwent a charging test which found no problems. Sometimes car cranks over but doesn't start, so I re-charge the battery then it starts. Also sometimes, after re-charging the battery, it wont start and just makes a clicking noise, checked the spark plugs they are all fine and working! HELP PLEASE
Nov 23, 2013 at 11:57 PM
  • 110,248 POSTS
When it doesn't start, does the starter crank the engine, trying to start it, or is the only thing you hear is a clicking?
Nov 26, 2013 at 2:55 AM
KEVROBBY
  • 5 POSTS
Thanks for the response! Sometimes the starter cranks the engine but theres no life, so I recharged the battery then it starts. A few weeks down the line it doesnt start again and doesnt even crank over it just makes the clicking noise! checked the spark plugs they look fine and are less than two years old and ignition coil less than 4 years old.
Nov 26, 2013 at 3:02 AM
  • 110,248 POSTS
If you are only getting a clicking sound, that tells me the battery is weak. When this happens, can you jump start the vehicle?
Nov 26, 2013 at 9:09 AM
KEVROBBY
  • 5 POSTS
When the problem first started and it cranked over but didn't start, we tried jump starting it and nothing happened. When the clicking noise was happening we never tried jump starting it.
Nov 26, 2013 at 1:52 PM
  • 110,248 POSTS
Since this happens over a period of time (weeks), I feel either the battery needs replaced, the alternator may not be recharging the battery or there is an electrical draw on the battery that is causing it to get weak.
Nov 26, 2013 at 10:22 PM
KEVROBBY
  • 5 POSTS
Thanks for your advice! At the garage today will let you know what they say
Nov 26, 2013 at 10:34 PM
  • 110,248 POSTS
I'll look for your reply.
Nov 26, 2013 at 10:37 PM
KEVROBBY
  • 5 POSTS
Just got the car back now, they said the throttle body was removed and found an excessive build up of oil/carbon around the throttle butterfly so cleaned that thoroughly and reset the throttle adaptations.
Nov 27, 2013 at 12:40 AM
  • 110,248 POSTS
I have to be honest, I'm not sure how that is related to the no crank issues you had. Regardless, let me know if it is running good for you or if you have other questions.
Nov 27, 2013 at 1:24 AM
