Let's start with how you are confirming fuel and spark. You need three things for the engine to start. Fuel, ignition/spark at the right time and then compression.
Let's assume you have compression for now and come back when we confirm fuel and spark.
Start with spraying some starter fluid in the intake and see if it fires. If not, pull a spark plug and connect it back to the wire and hold it against the block to see if you have spark.
Or let me know how you confirmed spark and fuel.
Here is a guide that goes into a little more detail:
If we confirm fuel and spark then let's do a compression check and let me know each cylinders number.
Thanks
Apr 2, 2020 at 4:17 AM
