Engine cranks but wont catch
70,000 MILES • 3.1L • V6 • FWD • AUTOMATIC
ROCKY9395
Just bought the car. It needed a jump to start and would run fine. Replaced with a new battery, twice, with 650cca. Now it cranks but will not catch, even with a jump. A couple of times it almost caught but that was it.
Aug 7, 2016 at 2:45 AM
HMAC300
  • 48,601 POSTS
try resetting security system or another key. your diode may be worn on that one. a new one wont work as it will need to be programmed to your car.
Aug 7, 2016 at 5:06 AM
ROCKY9395
There is no security system and it is a standard ignition key. It started fine the first time, without a jump. I do not think it is the key. It almost fully started after a plug was pulled out and plugged back in to the air filter cover. Maybe a compression issue?
Aug 8, 2016 at 6:28 AM
HMAC300
  • 48,601 POSTS
well there is a security system on it through the key even though it does not look like it. have it scanned for codes by a mechanic.
Aug 8, 2016 at 8:16 AM
  • 55,781 POSTS
Sometimes when you put a new battery in it can blow a fuse, also did you happen to jump it backwards? this will fry the computer, here is a guide so you can do some more checking
Check the fuel pressure as well. The pump may have went out.
Let us know what yo find
Best, Ken
Aug 8, 2016 at 10:35 AM
ROCKY9395
Ok thx I'll give these a try!
Aug 8, 2016 at 10:51 AM
ROCKY9395
Tried the starter fluid. The car started for about 20 seconds then puttered out, wouldn't restart.
Aug 15, 2016 at 7:20 AM
  • 55,781 POSTS
Okay, let's try check for injector pulse while it is not starting
here is a a guide that will help you
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Let me know what you find
Best, Ken
Aug 15, 2016 at 7:35 AM
