when down shifting the engine stay at 3200 rpm's until i come to a complete stop
198,000 MILES • 1.4L • 4 CYL • MANUAL
HIPPIECHIC
  • 9 POSTS
Randomly when I push the clutch to down shift or to come to a complete stops the engine will rev way up to around 3200 rpm's and will stay high like that until the car comes to a complete stop. Once at a complete stop the engine will idle back down and run normal. (It does not matter which gear I am in). This has happened when at highway speed and when only doing 25 mph. This issue is not a consistent issue, it not an everyday occurrence or a weekly issue its very random.
Oct 28, 2016 at 4:44 PM
SATURNTECH9
  • 30,869 POSTS
Have you ever changed your coolant temp sensor that can do some crazy things when they go bad.Have you checked for codes yet?
Nov 1, 2016 at 1:12 PM
HIPPIECHIC
  • 9 POSTS
I have not changed the coolant temp sensor and I currently do not have any codes. I will get back with the results. Thx
Dec 12, 2016 at 1:39 AM
  • 55,732 POSTS
Please let us know happens so it will help others.
Best, Ken
Dec 12, 2016 at 2:11 AM
