When driving the car at 80KPH the RPMs are just over 2,000 and when it’s at 90 it’s like about 2.5k, is this normal for the car?
Aug 12, 2023 at 9:43 PM
✓Experienced Mechanic
It sounds like the transmission is not shifting into overdrive, can you count the shifts to confirm there should be 4 shifts. Also, let's run the codes to see if any are stored.
Can you please shoot a quick video with your phone so I can hear the RPM noise? That way I can tell for sure what's going on. You can upload it here with your response.
