Engine
BIG FERN
  • 1990 ACURA INTEGRA
  • 100,000 MILES
My Carr is trowing out smoke and water out the tell pipe and smells like gas wen I tern it on
Tuesday, April 30th, 2013 AT 9:25 PM
CARADIODOC
  • 33,916 POSTS
Water at the tail pipe can be a byproduct of a properly functioning catalytic converter, but the multiple symptoms suggest a leaking cylinder head gasket. You can verify that by adding a small bottle of dark purple dye to the coolant. It will show up later under a black light as a bright yellow stain. If it shows up inside the tail pipe, the head gasket is leaking. The level in the coolant reservoir will be going down too.
Tuesday, April 30th, 2013 AT 9:30 PM
