Emissions test not working
119,000 MILES • 4.0L • V8 • 2WD • AUTOMATIC
MARKMICHAEL
Live in NY which requires an emissions test to past inspection. No service engine light on; have put on 3,000 miles since first trying to pass inspection. No codes thrown. But inspection says it does not pass. No codes come up. Any thoughts?
Nov 2, 2021 at 5:45 AM
  • 110,248 POSTS
If there are no diagnostic trouble codes, it should pass. If there is a problem with the emissions system, a check engine light should turn on.
Are they giving you any rationale for failure? The only thing I can think of is if the battery was disconnected or someone cleared codes. That would cause the monitors to indicate not ready (readiness). Basically, the system hasn't completed a component check yet. Thus, there could be a problem that the computer (PCM) hasn't recognized yet.
Additionally, the (EPA) guidelines allow one monitor "not ready" for 2001 or newer model year vehicles. So, if there is one monitor which is causing an issue, it can still be passed.
I hope this helps. Let me know if you have other questions.
Nov 2, 2021 at 12:20 PM
