emission control module
140,000 MILES
GARYSARTAIN
I need to know where it's located so I can replace it
Apr 27, 2013 at 7:04 AM
CARADIODOC
  • 34,413 POSTS
There is no such thing. The emissions control is a system that is built into the Engine Computer. Part of it has to do with calculating fuel metering and ignition timing to prevent excessive emissions, and part of it has to do with cleaning up what emissions does occur. The Engine Computer is mounted on the left inner fender.
Apr 27, 2013 at 7:39 AM
GARYSARTAIN
I think it is the ENGINE control module. Somewhere in the vicinity of the coil / distributor area.
Apr 29, 2013 at 5:19 AM
CARADIODOC
  • 34,413 POSTS
The Engine Computer, (Engine Control Module - ECM) is on the driver's inner fender. You didn't say which engine you have or what problem you're trying to solve. If your engine has a distributor there will be a pickup coil in it and possibly a small ignition module. GM used to have a huge problem with Engine Computers in the '80s and early '90s, but by '96 failures were not common.
Apr 29, 2013 at 6:06 AM
