Engine stalls
200,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
RANDY HOBBS2
I had driven the jeep about fifteen minutes and shut it off for about an hour. When I tried to start it, the dash lights did the self test and radio came on as usual, the starter started to engage, and then everything went out. I have headlights, dome lights, and horn, but nothing happens at all when I turn the ignition. I have changed the ignition switch, and the ignition switch actuator. I have checked and I have power coming to the ignition switch, but still nothing happens at all when I turn the key over. All of the fuses in the PDC under the hood are good, and all have 12.5 volts going to them. I have taken the starter off and had it tested, it is fine, and I have changed the starter relay in the PDC. I am normally really good with typical starting issues, but this one has me stumped. I am thinking a bad ground, but I have checked continuity between the engine block, body, and frame and they all seem good. Help me! LOL
Jun 11, 2017 at 7:36 AM
FREEMBA
  • 1,152 POSTS
Disconnect the small brown wire from the starter. Use a voltmeter to check for voltage at that wire when the ignition is turned to start (should be twelve volts). [red voltmeter lead to the brown wire and the black lead to a good ground]. If voltage is present, ignition switch is okay. If not, check fuse number twenty (in fuse block) and fuse number two (in power distribution center). Let me know what you find. Thanks.
Jun 11, 2017 at 9:03 AM
RANDY HOBBS2
Okay, all the fuses are good, I got zero voltage at the wire you mentioned. I do not think I was clear in my initial description. It is not just the starter that will not fire, I have no power to anything in the dash. No radio, no accessory power, and no gauges or dash lights. Nothing at all happens when the key turns. Could this possibly be some type of anti theft issue? Because it seems like the entire system is not working, except for the headlights and dome lights.
Jun 11, 2017 at 9:21 AM
CJ MEDEVAC
  • 11,000 POSTS
That was zero volts when the key was turned to "start"?
The Medic
Jun 11, 2017 at 10:58 AM
RANDY HOBBS2
Yes, zero voltage when the key was turned to start.
Jun 12, 2017 at 3:21 AM
  • 55,709 POSTS
What comes to mind for me is a bad battery or battery cables. Inspect the cables and look for bugling. Also, move the cables around to see if you can get the electrical to come back etc.
Cheers, Ken
Jun 12, 2017 at 5:13 AM
RANDY HOBBS2
Problem solved guys. One of the hot wires coming out of the PDC box, that goes to the ignition switch was corroded. Cut out the bad spot, replaced the end, shrink wrapped and I'm back on the road
Jun 18, 2017 at 7:50 AM
CJ MEDEVAC
  • 11,000 POSTS
Wonderful!
Glad you are back on the road.
Be sure to wave at the other Real Jeeps.
The Medic
Jun 18, 2017 at 12:32 PM
  • 55,709 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers, Ken
Jun 19, 2017 at 3:04 AM
