12 volt direct drain electrical problem
40 MILES • 4.1L
PETER BAGDON
Can you try to help solve a 12v direct drain electrical problem? I just got this car it was was sitting over 30 years. Previous owner put a fuel pump and tank in it. He couldn't get it running. I believe he seriously overcharged it. The new battery he bought went bad. The alternator diodes were shorted. After repairing the alternator I still have a 12v drain. The ignition switch or starter isn't shorted. If I unplug the ignition switch it goes away.There's a wire that's hot after i plug in the switch that goes to a grey ? Junction box ? About at the top of the dashboard looking from below. Any ideas what that is? I know Cadillac was the testing grounds for new things. I have never seen this and it has weird pronglike plugs.
Apr 21, 2021 at 7:19 AM
Good evening,
The battery drains from current flow or amps, not voltage. You will always show voltage but you need to measure the current.
I attached a guide for you to follow for checking the drain correctly. The normal draw is 50-75 milliamps.
https://www.2carpros.com/articles/car-battery-dead-overnight
Apr 21, 2021 at 8:57 AM
