Adding a trailer hitch and wiring to my vehicle
101,000 MILES • 3.7L • VR6 • 4WD • AUTOMATIC
KIRTHOWE
I am adding a trailer hitch and wiring to my vehicle. I want to just tap into the rear tail lights to hook up the four wire flat connector for the trailer wiring. Is it safe to do this, or do I have to spend the $60.00 to purchase a special wiring adapter to plug into the wiring harness? I do not want to damage the cars computer, or cause weird electrical problems.
Oct 31, 2017 at 1:00 PM
WRENCHTECH
  • 20,758 POSTS
Yes, you really should spend the money. I believe the reason for the adapter is that you have separate turn signal and brake lights and the trailer uses one light for both.
The truck should be equipped with a trailer tap in the rear harness that allows you to buy an adapter that simply plugs into their trailer wiring plug.
Nov 1, 2017 at 2:28 AM
KIRTHOWE
Okay, I was afraid that was going to be the case. Thank you.
Nov 1, 2017 at 5:56 AM
