Will not crank
2001 HYUNDAI SONATA
116,500 MILES • 3.3L • V6 • 2WD • AUTOMATIC
RICHARD HONE
A couple weeks ago it started knocking like it was throwing a rod and check engine light came on. Shut it off and checked it when I restarted it ran fine with no noises. Drove seven to eight times with no problems. Shut it off and now it will not turn over. Got power to everything else though.
Mar 31, 2018 at 10:00 AM
KHLOW2008
  • CERTIFIED EXPERT
  • 41,814 POSTS
Manually crank the engine to check if it is seized. If not, have the starter tested. Check for power supply to the starter while cranking
Apr 1, 2018 at 12:38 AM
