Battery saver function activated and lost all electrical power
149,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
TONYA2235
While driving home the other day battery saver function activated. I get home turn car off go to truck to unload groceries and trunk won't open and alarm remote not working. So I got back in and tried to start it again and nothing no beeps no dash lights nothing absolutely no electrical power. So my neighbor comes over lifts the hood and I assume bumped something and all power is restored all the dash lights and dings I turn key back off and repeat no electrical power. So I get online do some research and find the issue with negative battery cable. And I had at some point experienced all the symptoms described. Radio turning on and off, stibilatrac light, service anti theft system. So I replaced battery cable and trickle charged the battery. But still zero power. I'm stumped unless I possibly don't have it grounded good enough. Please help.
Jun 8, 2020 at 10:29 PM
Good morning,
Can you give me the battery voltage at the battery?
Did you clean both cables real well?
I would also check the charge rate from the alternator.
Jun 9, 2020 at 1:40 AM
Did you reply? I got an email but nothing came through.
Jun 9, 2020 at 6:18 PM
