EFI fuse
250,000 MILES • 3.0L • 6 CYL • 4WD • MANUAL
DANIEL ADRIAN ARNAIZ CARVAJAL
I am trying to find and fix a battery power drainage problem. I found that the EFI fuse located in the engine compartment fuse box shows a load when the engine is off. Is this normal? I suspect it is not, and since I am no expert I need to ask.
Thanks for your help!
Mar 15, 2018 at 4:29 AM
WRENCHTECH
  • 20,760 POSTS
It could be on a timer so you have to monitor it without interrupting the circuit for fifteen minutes or more.
Mar 15, 2018 at 8:37 AM
Thanks Wrenchtech, I will monitor as you suggest and see what it does.
Mar 15, 2018 at 11:24 AM
WRENCHTECH
  • 20,760 POSTS
Make sure you do not interrupt the circuit as that will just start the timers over again.
Mar 15, 2018 at 11:36 AM
noted...thanks again!
Mar 15, 2018 at 8:17 PM
