1996 Eagle Vision lock cylinder drilled out for towing
1996 EAGLE VISION
129,000 MILES • 6 CYL • FWD • AUTOMATIC
PARTSGIRL
i recently purchased a 1996 Eagle Vision that had it's ignition lock cylinder drilled out by a towing company. I purchased a new cylinder and installed it. The car will not start. The starter only clicks. Since the owner told me that the car was running before the lock cylinder was drilled, I have to assume that I did something wrong when I installed the new lock cylinder. HELP!!!
Jun 11, 2008 at 8:41 AM
DOCFIXIT
  • 18,828 POSTS
Check battery voltage it should be 12.45 or higher if not try jumping it with another batt
Let me know
Jun 11, 2008 at 9:38 AM
PARTSGIRL
i did jump it. still nothing. that was my first thought too.
Jun 11, 2008 at 9:40 AM
DOCFIXIT
  • 18,828 POSTS
If you have a volt meter check voltage at the solenoid have somebody turn the key see if 12+volts is there. If not there is a voltage drop somewhere we need to find. Just to see if all systems are go get a jumper wire have the key on and jump from the batt cable to the smaller solenoid term. If she fires we know that all is good and we need to focus on the ign switch
Let me know
Jun 11, 2008 at 10:36 AM
PARTSGIRL
thank you. will try that tonight and let you know
Jun 12, 2008 at 7:49 AM
