1993 Eagle Vision Dash and Tail Lights are out
1993 EAGLE VISION
149,000 MILES • 6 CYL • FWD • AUTOMATIC
DIMEBAGHEADSH0T
Okay, so I hit a stop sign the other night when the weather was really bad out, it took out my turn signal light and sideview mirror on my passenger side. Ever since then, my dash lights and my tail lights don't come on when I turn on my lights. The only time my tail lights come on are when I hit my brakes. My head lights still work fine. So, I checked ALL my fuses.... they are fine. I was told since the fuses are fine, it might just be because my turn signal light was gone so the electrical circuit wasn't complete thus my tail lights and dash won't work. It turned out that was wrong because I replaced the turn signal light and that did not fix the problem... Help Please.
Mar 4, 2010 at 11:45 AM
2CARPRO JACK
  • 11,533 POSTS
My software has very limited wiring diagrams for your car. Check the fusible links at the battery first.By all fuses do you mean in the underhood and underdash fuse blocks? did you check them with a test light? do the front running lights work when headlights are on?
Mar 7, 2010 at 11:17 PM
