1997 Eagle Talon code PO100
ECLIPSETSI
  • 1997 EAGLE TALON
  • 4 CYL
  • AWD
  • 10 MILES
My car is acting sluggish I run the codes and it gives me po100 I changed the sparkplugs but it still runs sluggish could it be the altinator
Tuesday, May 5th, 2009 AT 1:47 PM
WHITEBOYZRACING
  • 12 POSTS
A code P0100 may mean that one or more of the following has happened:
The MAF may be disconnected, or a wiring connection may be bad
The MAF sensor may be faulty.
That is why you are running sluggish. Buy a new Maf or try cleaning it with a MAF/MAS ait cleaner from yur local parts store. It is located right after your airbox on the intake tube. It is a black plastic box with a harness connected to it, it reads the incoming air before going into the turbo. If you run into anymore problems just give me a holler.
Saturday, March 6th, 2010 AT 10:21 PM
