1993 Eagle Talon Idle Problem
1993 EAGLE TALON
202,000 MILES • 4 CYL • 2WD • MANUAL
MACGYVER
When Cold the car had a hard time idleing until you warmed it up a little. The heater in the car was having problems too. I changed the Thermostat last night and found the old one was stuck open. After replacing the thermostat, the car idles fast when cold then once warmed up it starts to idle down then up then down and keeps pulsating as such. Then you drive it, it seems ok but when you stop at a stop sign it starts idling up and down again.
Jan 15, 2008 at 12:10 AM
LEGITIMATE007
  • 5,121 POSTS
have your idle air control valve checked . they are the culprit most of the time.
Jan 15, 2008 at 1:03 AM
MACGYVER
[quote:f62142161c="legitimate007"]have your idle air control valve checked . they are the culprit most of the time.[/quote:f62142161c]
Thank you. You were right. I unplugged the idle air control valve on the filter compartment and clean the plug with contact cleaner. It fixed the problem. You guys Rock!
Jan 15, 2008 at 11:00 PM
LEGITIMATE007
  • 5,121 POSTS
awesome
Jan 16, 2008 at 12:02 AM
