Dual fuel VE2 commodore LPG shaking
57,000 MILES • 3.6L • V6 • RWD • AUTOMATIC
ROBERT CLB
At about 50000km (under new warranty)the car started to give the engine warning light when at idle during driving eg at traffic lights. Idle was becoming rough before the warning light and stayed that way, giving less power on take off. Holden dealer diagnostic showed no error. Switching to petrol returned to normal running but warning light stayed on. After cooling down, on next start, the warning light was off and Holden diagnostic showed nothing. Eventually, I managed to get the car to a Holden dealer while the light was on and the engine idling very roughly. They diagnosed coil pack failure and fitted these. Now, the problem is worse, with the car not needing to be hot for it to happen. Car now just out of new car warranty, but take it that fix must be done under warranty as it's never been fixed. I can't sell the car when it is like this! I hear of other dual fuel cars like this..even getting the name "Harlem Shake" but no solutions posted. Thankyou
Mar 29, 2014 at 4:46 PM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
it is possible to need another coil pack if they only replaced one. this is normal. coil packs aren't expensive and are easy to install. do you have a steady warning light again? even if the light goes out there will be a history of the code stored in the engines computer that can be read with a diagnostic computer
Mar 29, 2014 at 11:30 PM
