I have a high energy ignition adjustable spark plug tester. What I want to know is where on the voltage scale should I set it? On the voltage scale it has 20, 30, 40 this is to test coil on plugs. I would appreciate it I tested them, but I know I had it to low I had it way down on 20, Thank You.
Mar 6, 2016 at 12:59 AM
