The truck will not start anymore I recently replaced the harness and the idm with a used one because of an issue with the wires having a short somewhere. Now I am getting all of these codes when I do an injector test. I also replaced the drivers side valve cover. The truck was running before this bit with a rough idle and oil pressure sensor issue. I’m not sure what’s going on now that it won’t start
Sep 15, 2024 at 6:41 PM
