banging noise when accelerating
2001 MERCURY MOUNTAINEER
150,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
MARK FRIZZELL
  • 142 POSTS
All of a sudden I have this banging noise at acceleration. Does not seem like transmission is slipping, it feels more like transfer case chain when they slip.
So I got Vehicle up off the ground in drive, ( not running) and turned driveshaft feeling for resistance or anything different, everything seemed okay. so started vehicle put in drive and looked at everything, noticed all wheels turning except front left wheel was not upon acceleration it was trying to grab. Heard some noises so removed front differential cover found nothing out of norm teeth looked okay,
I know this was lengthy but tried to be as descriptive as possible,
I do not see anything loose but definitely something is slipping, CV does not look bad, should that front left wheel not be pulling like the other three?
Mar 7, 2018 at 10:45 PM
Good morning.
No, you do not have a positraction in the front differential. off the ground only one wheel will turn.
As far as the noise, I would first check the driveshaft universal joints to see if any are locked up. you will need to remove the shaft and move the joint manually.
Mar 7, 2018 at 11:00 PM
MARK FRIZZELL
  • 142 POSTS
Would it be possible that a CV join that I visually cannot see is slipping under load?
Mar 7, 2018 at 11:24 PM
It will not be slipping it will be knocking from a burr in the race or the bearing. very tough to see without removing the boots and visibly inspecting.
You can manipulate the joint up and down and around and if there is a burr, you will feel it. that is why I said to check the universals in the driveshaft.
Mar 8, 2018 at 12:11 AM
