Hi, hoping you can make sense of this. This is from the garage today. I have the car listed above it is a Coupe 59 plate.
So the DPF is blocked, which has caused back pressure and puts massive strain on the turbo. So with this being the case the car would need either the DPF cleaned or replaced. A new turbo is also required.
Is that a good answer?
Original diagnosis was straight DPF block and to remove and clean or remap. Then garage said three days later that the turbo (as above)!
Cost as originally quoted at £540 - Then raised to £1700.
Need help please.
Need help please.
Sep 12, 2017 at 5:32 AM
