Rough idle and shuts off when the transmission is shifted into gear?
184,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
ALWHO
The engine won't idle smooth shuts off soon as you put in gear.
I have replaced the following:
1. complete Distributor, Coil, Plugs, Plug wires.
2. Drop tank cleaned it and replaced the fuel pump, and frame filter.
3. Replaced injectors, fuel regulator.
4. Replaced the EGR, 02 sensor, Throttle sensor, idle sensor, vacuum lines, and every other sensor i could find.
Mainly since Trucks 30 years old and I have changed everything until now.
What am I missing? Help
Nov 12, 2023 at 12:58 AM
  • 110,248 POSTS
It sounds like low fuel pressure or a large vacuum leak. Have you checked to see if there are any trouble codes stored? This truck has an OBD1 system and doesn't require a scan tool to retrieve codes. All you need is a short jumper wire or even a paper clip.
Here is a link that explains how to do it:
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Let me know if you checked for engine vacuum leaks as well as the EGR valve. If it is stuck open, that can cause this.
Nov 12, 2023 at 12:40 PM
ALWHO
I fuel filter and cleaned tank replaced fuel pump have replaced vacuum lines and EGR valve, also changed fuel pump and filter only is when i try to keep running is 34 and once 43.
Nov 12, 2023 at 11:54 PM
FFEATHERINGILL
Code 34 is MAP sensor voltage, a circuit code. Prove the harness and if it checks good then faulty sensor or PCM.
Nov 13, 2023 at 9:31 AM
FFEATHERINGILL
Double check your distributor timing, be sure to disconnect the timing spout connector before starting when timing it.
Nov 13, 2023 at 9:33 AM
