Does Nissan Atlima 2017 has turn signal flasher?
18,000 MILES
TAHIRPOLANI
I want to know the location of turn signal flasher relay of nissan altima 2017 if it has any or it is controlled by BCM?
Jan 25, 2019 at 8:25 AM
  • 110,248 POSTS
Hi and thanks for using 2carpros.com
The BCM controls it. Here is a description of how the system works.
System Description
TURN SIGNAL OPERATION
When the combination switch (lighting and turn signal switch) is in LH or RH turn position with the ignition switch in the ON position, the BCM receives input requesting the turn RH or turn LH lamps to illuminate. The BCM controls the turn signal power to the respective turn signal lamp. The BCM also sends a turn indicator signal ON request via the CAN communication lines to the combination meter. The combination meter then activates the appropriate turn signal indicator and audible buzzer
Let me know if this answers your questions or if you have others, let me know.
Jan 25, 2019 at 10:35 AM
