It all started on Christmas this year sounded as if undercarriage fell from under the van then it stalled for a minute or two.was able to drive home a couple miles very slowly smelled like burnt wires and front drive tire hub was very hott..was told needed new rotors.got new rotors and was told the center nut; was not tight it was loose some play in wheel.retightened as needed now I have a grinding metal scaping noise coming from same tire I was told it's the wheel bearings and I cannot find the front wheel hub assembly anywhere.was also told tire rod axle and also the CV boot is torn was regreased don't know if that has anything to do with the noise.please help
Apr 1, 2018 at 2:10 AM
