2000 Dodge Van Engine codes
DBLOUNT1992
Engine Mechanical problem
2000 Dodge Van Two Wheel Drive Automatic
i need the causes for the codes P1594, P0443, and P0505 for a 2000 dodge ram van with a V6 318 in it
Dec 16, 2009 at 1:46 PM
CH112063
  • 1,320 POSTS
P1594 is charging voltage too high. Alternator is charging with voltage beyond the tolerance and has set this code.
P0443 is emissions related.Evaporative, emissions
p0505 is an idle speed motor code.
it may be an internal engine controller problem or any of a couple of problems. the first code could possibly cause all 3. you have to record each code, and re-test. there may be a re-programming bulletin that can help, It may be a good time to call a dealer. ok? hope its ok.
Dec 23, 2009 at 12:54 PM
