1995 Dodge Van tried everything you said. Still cuts out
DUZITALL
  • 1995 DODGE VAN
  • 6 CYL
  • 21,000 MILES
I am not satissfied with the answers I recieved concerning the continual intermittent shut down of my vans ECM. Do the relays( ignition, shut off and so on)talk to the ECM and tell it to shut down? How does it know to do this? Who has knowledge about how this works? Remember, no engine light comes on it just shuts down while driving. Also have replaced crank and cam sensors. Also have R&R ECM(used)and swapped shutoff relay with the one next to it on driver side firewallbehind master cylinder. Please come up with viable course of action!
Saturday, December 19th, 2009 AT 7:40 AM
CH112063
  • 1,320 POSTS
I am very sorry for all the frustration your van has been causing you. I will relate a couple of experiences I had with my vans.
If you open the hood, if you can think of it as a little hood, you'll see the harness, a few had shorting problems there, you could just grab the wires, in the center, it could turn the engine off.
The vehicle speed sensor would also kill power at highway speeds intermittantly, no codes. The reason for the electronics in diagnostics is especially important if your having this type of problem.
I hope the computer that runs your engine can pick-up any last wire and that wires circuit is usually the last thing it reads, giving a technician a starting point. Many friends also had problems with VSS's. Hope it helps in any small way. Can you read it(engine comp.) For codes? You'll get it, and when youi finally get it fixed, you'll have experience money can't buy.
Wednesday, December 23rd, 2009 AT 8:30 PM
