1995 Dodge Van Fuel Problem
MONTYROB
  • 1995 DODGE VAN
  • V8
  • 100,000 MILES
When ever the temp gets really warm the van acts like it is not getting fuel so there fore it can't spark
Sunday, May 3rd, 2009 AT 4:35 PM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, ECM, Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Sunday, May 3rd, 2009 AT 5:10 PM
Related General Content
