2005 Dodge Truck key switch
95,000 MILES • V8 • 2WD • AUTOMATIC
WJ HOLLI
I can put the key in the switch and it will not turn>I called the dealer and this does not have a chip in it.I have a new switch and key but I can't turn it far enuff to unlock the little drop down lock
Jan 16, 2010 at 1:03 AM
MATHIASO
  • 1,209 POSTS
HELLO _wj holli
Spray w-d 40/ in the lock hole, insert the key and tap on it lightly with a hammer, turn the wheel lightly while you’re trying the key.
Make also sure the car is in park or neutral. If not, the key won’t turn.
When you get it started, change the cylinder to avoid future problems
Jan 17, 2010 at 8:44 AM
