Many digital thermostats have programmable fan timing for off-delay timing to slightly increase efficiency (fan stays on for pre-determined time after A/C shuts off) but the thermostat should have nothing to do with what you are describing.
You may have a problem with your A/C, Especially if it is happening more often.
One thing to check is if the thermostat has a time delay built in for compressor safety. If your unit has a built in time delay, it will add to the thermostat time delay and the unit may not come on for 10 minutes or so.
If the thermostat has a time delay, you can usually program it so it has no time delay. Try that and if that doesn't work, you may need service.
SPONSORED LINKS
Tuesday, July 20th, 2010 AT 6:02 AM
