1996 Dodge Truck
RJSDISPOSAL
Electrical problem
1996 Dodge Truck V8 Four Wheel Drive Automatic 104.63 miles
I removed a 5.9L from a 94 Dodge put it in a 96 Dodge that had an 5.2L will I need to change the computer and wireing harness to run correct
Mar 30, 2010 at 4:48 AM
BRIAN 1
  • 1,030 POSTS
you will need to change it,because your going from a 5.9 to a 5.2,the harness and wiring will be a little different.yes you will have to change the computer also because the 94 vehicle is OBD and the 96 is Obd 2.
Mar 31, 2010 at 10:53 AM
