1996 Dodge Stratus Coolant Boiling
THEWALL0218
1996 dodge stratus 2.0 liter 133000 miles the anti freeze in the reserve is boiling ive tried replacing the thermostat with no luck what could be causing this
Aug 14, 2006 at 4:15 AM
DAKOTABS
  • 8 POSTS
try flushing out the radiator
Aug 14, 2006 at 12:40 PM
MIKEYBDMAN
  • 623 POSTS
[quote:cdf960c81a="thewall0218"]1996 dodge stratus 2.0 liter 133000 miles the anti freeze in the reserve is boiling ive tried replacing the thermostat with no luck what could be causing this[/quote:cdf960c81a]
What is the temperature on your temp gauge reading? If indeed the fluid is that hot, there are a few things you should check. Are you loosing fluid? Is your water pump working? Is the cooling fan in front of your radiator working when it is that hot?
In all vehicles, the thermostat is there to speed up the time it takes for your engine to heat up. The water pump is there to flow the water thru the system. The radiator is there to cool the water, and the fan is there to limit the top end temperature of the coolant. If it is getting too hot, I would check the fan first. If that is working properly, then it may vary well be the radiator has lost its effectivness. A flush may help, but if the radiator is that bad, a new one may be what is needed.
If you are loosing fluid, that opens the door to a whole new set of problems.
Aug 14, 2006 at 12:50 PM
Suggested Repair
Check the temperature gauge, cooling fan operation when hot, water pump flow, and whether coolant is being lost. If the fan works, flush the radiator or replace it if it no longer cools effectively.
Conversation Summary
The owner of a 1996 Dodge Stratus 2.0 reports boiling coolant in the reserve after replacing the thermostat. One reply suggests flushing the radiator. The expert advises checking the temperature gauge, coolant loss, water pump, and cooling fan first, then considering a radiator flush or replacement if the radiator is no longer effective.
