2003 Dodge Stratus Engine stalls
78,000 MILES • 6 CYL • 2WD • AUTOMATIC
APANDA
Lately my stratus will stall at times when either braking or if the air conditioning is on at low rpm.
Can you let me know what I should be looking for to correct this condition.
Oct 25, 2009 at 4:08 AM
  • 110,248 POSTS
Has the check engine light come on?
Oct 26, 2009 at 4:12 AM
APANDA
No the light is not on nor does it come on.
Oct 26, 2009 at 5:19 AM
  • 110,248 POSTS
If the light doesn't come on, that opens things up. First, I would like you to check for vacuum leaks, check the EGR valve to make sure it is working properly, and if that all checks out, I need you to check fuel pump pressure.
Let me know if you need directions for checking fuel pump pressure.
Let me know what you find.
Oct 26, 2009 at 5:47 AM
APANDA
The throttle body had some carbon build up. Per the direction of a mechanic intown the carbon was cleaned out of the throttle body and valve pivot. I then test drove the car for 1 hour at all speeds and stoping conditions with the defroster and air conditioner running. The vechicle no longer stalls hopefull that that takes care of the problem. If it does not I will check the fuel pump pressure.
Thank You for your help, You guys have a great site.
Oct 26, 2009 at 8:17 AM
  • 110,248 POSTS
I'm glad that took care of it. Let us know if you have other questions and thanks for using 2carpros.com.
Oct 26, 2009 at 2:11 PM
